Dave Cunningham
- May 20, 2024
- R-23 (Outboard)
- Waveyboy
Does the cutwater use a transducer for the garmin depth reading?
That is where our 32 CB transducer is also. Difficult to get at and repair unless you're a 95 pound contortionist...Yes to transducer, and on our C30 sedan the transducer was accessed inside the hatch at the base of the stateroom berth, next to where the shower sump box is.
I have the 2018 30 with outboards. Was fishing out of SWFL well offshore and mine quit. Found the typical airmar in same location as Sailor did but found two. I found first one intact still in its mount, so went searching for loose wires. When searching around for loose wires I found some and pulled out the second transducer which is the one being sourced. It had pooped out of its mount and was rolling around. Wasn't till I pulled on the wires did I know I had a second transducer - found the mount and back up in working. I have owned numerous vessels with read thru hull transducers. over time and hard sea conditions that mount can spring a leak at base mounting point at the hull or base may get a crack (just old plastic) and liquid runs out causing failure to read. Key points are don't install over finished gel coast inside the hull (will not read), sand that interior gel coat off to clean fiberglass as it will give a clear read and a mounting good mounting point for the base with 5200. be careful with mounting the base as the mount is marked with degrees must get this right for proper fit against the hull (dry fit first). I see the mention to fill the mounting cup with antifreeze. I have always used mineral oil but I'm in Fl so not familiar with cold installation concerns. So, it needs a liquid and I have used bottled water in a pinch.Does the cutwater use a transducer for the garmin depth reading?
