Transducer Location on R31
HappyPlace
C-302 SC
FMLT3133A414
Happy Place
Can anyone tell me where the transducer is located on our 2014 R31?
Al Sr.
On my 2016 R31CB, the transducer is accessible from under the rear cockpit seat, and is found on the hull just to the right of centerline and about 16 inches from the transom.
Do you have a generator? If so, is it aft of the generator toward the transom? I do not have immediate access to the boat and will look next weekend! I want to make sure the keel offset in the Garmin is setup correctly.
Thx....Al Sr.
I do not have a generator. My transducer is located partly underneath the wood platform (aft toward the transom) where I believe a generator would have been installed. Without a generator it is very easy to access since I can climb right down in the hole. Hopefully it won't be too tough to access with a generator in place. Good luck!
The transducer remains in the same place regardless of a Generator or not.
Thank you,
Thank you all!!!
Al Sr.
