allardiced
- Nov 12, 2020
- C-30 CB
- Little Blue T
Hi all,
I have a 2021 R29-CB with a Volvo Penta D4-320-IG engine and HS68A-A simple reverse gear transmission. For the past month or so, I have occasionally gotten the following error on my Volvo panel:
I suspect the sensor is faulty but how can I verify? And is this an easy item to replace? Or could this be an indication that the cooling system for the transmission is not functioning properly? I believe I found the part # for the sensor (17202573) but do I need to buy the O-ring, adapter, and gasket which are related to it? I believe these are parts # 25 thru 28 on this diagram => https://www.volvopenta.com/shop/0/part-sections/54166033. Is this what is needed to replace the sensor?
Any clarity would be appreciated. I'm concerned there is somethign wrong with the transmission and I won't know it without the working pressure/temperature sensor :/
Regards,
-Darryl
"Little Blue T"
I have the Volvo Easy Connect app on my phone connected to the Volvo Easy Connect Gateway device on the boat and therefore I can see the values on the Volvo system, and they are showing very strange values, such as "418" for Transmission Pressure (PSI) and "-4" for Transmission Temp (degrees F).Transmission oil temperature sensor failure
Regards,
-Darryl
"Little Blue T"
