Bentsea
- Jul 23, 2024
- R-27 (Outboard)
- Bent Voyage
I have a 2023, Ranger Tug 27 OB Northwest edition. The transom sink does not drain all the way to the outside of the boat. There are two other drains that are connected to it, the engine mount drain area and the large live well in the transom. As you can see from the photo included the drain exits at or below the water and appears to be clogged. When I fill the transom sink the engine mount drain will fill up with water. I have two questions:
1) what is the best way to clean this out. I clearly cannot remove the hoses to clean as that is the only thing keeping the water out.
2) should this be at or below the water as in the photo? We do have the dinghy stand with the dinghy on. The boat is only half full of gas with no one on board in the photo.
I am concerned that the only thing preventing the boat from sinking is a common drain hose and hose clamps with the drain outlet under water.
