CaptT
- Oct 8, 2020
- R-21 EC
- FMLC2824L415
- NO FENCES
The Admiral and I are planning to do the Great Loop next year using our C 28. We were taken aback when we read the statements made in the book " Looper's Companion Guide" claiming the newer high speed diesel engines are not a good choice to accomplish this trip as they are not designed to run at lower speeds. The author goes on to say these engines will require "detuning" and cooler system changes, as well as reduced injector size, to protect against carbonization problems.
Is this true? I have read the Volvo D4 260 engine does like to be worked and opened up on a regular basis but does it require the changes stated above to cruise at a slower more economical rate?
Has any done prolonged cruising at slower speeds that caused carbonization issues? Any Looper's out there that used a similar boat/engine?
Thanks in advance for any insight you can provide!
CaptT
CaptT
