Hi Jim,
Yes, I masked the area where the trim tab anode is installed. I suspect that the epoxy primer helped to isolate the stainless steel trim tab from the salt water and reduced the ion flow allowing the zinc anode to last much longer.
Hi Jurgen,
The gavanic isoloator helps by blocking DC current (caused by low galvanic voltages, less than 1 1/2V or so) between your boat and others in the marina. When you connect shore power you are also connecting your boats ground (and underwater metals) to the ground of every other boat that is also on shore power. If other boats do not have proper anode protection then the anodes on your boat can end out protecting them (and get rapidly consumed). Another boat with faulty DC wiring, such as broken insulation in bilge pump wiring, can induce even higher currents and eat anodes at an alarming rate.
The gavanic isolator still allows AC current flow to allow a breaker to trip if there is an AC fault condition. I used a Fail Safe isolator, if it fails it should go into a short circuit. It will no longer provide galvanic isolation but will continue to provide AC fault protection. They need to be tested periodically, this is easily done using the diode test function on a digital multimeter. I plan to do this each year before launch.
An isolation transformer is even better than a galvanic isolator, but the transformer is much larger, heavier, and costs more.
Howard
