NorthernFocus
- Jun 29, 2014
- Alaska
- Website
- www.northernfocusphotography.com
- R-25 Classic
- FMLT25910808
- Divine Focus
ALL hydrocarbon fuels will auto ignite. One example is a gasoline engine "dieseling" or "pinging" due to combustion occurring before the spark plug fires. It is true that the auto ignition temperature of gasoline is slightly higher than diesel but not enough to be meaningful. Either one sprayed on steel that is hot enough to visibly glow red will likely auto ignite.
Statistically there are far more fires on gas powered boats than diesel. That said, diesel is highly combustible when either vaporized or atomized. Modern common rail diesel engines like we all have in our Rangers have a high pressure fuel delivery system that will produce just such an atomized spray if the high pressure tubing cracks or a fitting comes loose. And diesel does contain a lot more BTUs per gallon and once ignited burns much hotter than gasoline. Not like that's going to matter to a guy on a boat that's on fire.
All that said, the most common fuel leaks are supply hoses, tank fitting, and filter housings. And there is one thing for certain. As unpleasant as it may smell, you can motor on home with a bilge full of diesel. With a bilge full of gas you better get off the boat before it finds a spark.
There must be some genetic, gender based sensitivity to the smell of diesel. My wife also has zero tolerance of diesel odor, either fuel or exhaust. That has forced me to develop very good hygiene practices when fueling, changing filters, etc. Liberal use of absorbent sheets contains the liquid and a spray bottle with a 10:1 solution of Dawn removes that tenacious diesel film quite well.
