ixlr8
- May 2, 2017
- R-27 (Outboard)
- FLMT2762C818
- Non-Fluid Motion Model
- 2018 R-27OB w/Yam 300
- Maggie
Hmm, I turn off the battery switch whenever I leave my boat, a 27OB. Everytime I turn it on, I find the autopilot display on. I will have to search thru the menu's to see if I can stop it from happening. Thank you for the heads up there is a setting that can change this.jagizzi":1r5fdtnr said:If it is the same autopilot that is on the 23, there is an auto on setting in the setting menu. I may not have the Garmin terminology but it was obvious from the name.
Dig around and make that change and you should be able to make that stop.
Jim
