GaylesFaerie
- Jul 20, 2020
- C-28
- FMLT2701D112
- Gayles Faerie
Questions for the gang: I have a 2012 R27 with an antenna of some sort (TV?) on the roof behind the mast in the shape of a flying saucer about 10" across. It is literally disintegrating with the top and bottom halves totally separated and leaving bits and pieces of plastic on the roof. There is a coax connection underneath that goes thru the roof.
1. What exactly is this used for? OTA signals from a TV broadcast antenna?
2. What is called? I can't make out any product names or indication of manufacturer because it is so decayed.
3. Where might I find a proper replacement with the right specifications?
4. Do I have to replace it or is there a new and improved way of replacing its functionality.
Thanks in advance!
Gary
Thanks in advance!
Gary
