Tym
- Jan 13, 2010
- C-288 C
- FMLT2915K910
- Circle T
Hi Tugnuts,
During the very last day of cruising on the "Circle T" during our two-month long PNW trip this year, I learned two lessons which I think are worthwhile to share. The Circle T is a Ranger 29, but I would guess that the mechanical aspects here are the same on all of the Tugs with Yanmar engines. I don't know about the Cummings and Volvo engines.
First lesson: We cruised from Bell Harbor to Blake Island to meet some old friends, and stopped at the pump-out dock to clean out the black water tank before proceeding to the final spot for the night. After shutting down, tying up, and pumping out the tank, I turned the key to start the engine, and for the first time ever, the engine would not start. It turned over strongly, but just cranked and would not start. A check of the engine compartment showed nothing obvious. And, yes, there was plenty of fuel in the tank...
Mercifully, I decided to do nothing and let it cool down thinking that perhaps I had some sort of vapor lock. Meanwhile, I started the generator and ran the battery charger so that batteries would not be an issue. I say "mercifully" as during this time I put in a call to Andrew, and he returned the call before I started to crank the engine again. His first words "Do NOT crank the engine !! Do you hear me? Do NOT crank the engine!!!"
Lesson Learned: If the engine cranks but will not start, you are sucking in raw sea water through your impeller which can end up inside your engine and do damage. Don't know exactly how, but it sounds expensive. Andrew instructed me to close the engine's through-hull to prevent this from happening, and then deal with the problem.
He had me shut down the generator so I could hear, and then have my wife June turn the ignition key one click (to the beep) while I was down in the engine compartment listening for the electric fuel pump. It comes on and runs for about 20 seconds each time the key is turned to the first click. It was working, but was quieter than I would have imagined. (I'd suggest you listen to yours now while it's working, so you'll know what it's supposed to sound like if this happens to you.) She then turned the key to the "off" position, and then back to the first click a total of 8 times, each time waiting the 20 seconds until the fuel pump had shut off. After this, she turned the key to "start", the engine instantly started, and I quickly opened the through-hull. Phew!
After getting the engine started, we cancelled our plan to visit our friends at Blake and elected to proceed non-stop to Everett where there is a Yanmar dealer and where we planned to have the boat taken out of the water for it's return trip to San Pedro, CA. I thought I might have a clogged fuel filter, so was prepared to INCREASE the throttle in case of any engine burps along the way. I also had the enroute alternate marinas in mind. But the engine ran perfectly. An altogether different lesson was in store for us next...
Lesson Two: After 2 months of cruising and about 130 engine hours logged, with less than 1/2 mile to go to the guest dock at Everett Marina, I caught a glimpse of a huge log right in front of us! Too late. I turned the wheel hard left, and then watched as my life's story played out in front of my eyes. After what seemed like an eternity, but in actuality was less than a second, WHAM. After it struck the front and went under the boat, I felt a vibration in the steering wheel. Aughs. We made it to the guest dock and checked for leaks and obvious damage, but appeared to be okay -- my mood notwithstanding.
When the boat was taken out of the water the following day, inspection showed a bent prop blade and a broken prop shear pin. So if the shear pin was broken, how did I move from the point of impact to the dock, and the next day the few hundred yards from the dock to the trailer ramp? Another call to Andrew...
Here's the lesson: Andrew tells me that the propeller's tube for the shaft is tapered, being smaller at the rear than it is at the front. This way, if the shear pin fails like ours did, but the engine is turning in the direction for forward thrust, then the propeller will push itself forward on the shaft but be held in place by the small diameter rear end, and that compression will allow enough torque to enable one to proceed forward at a slow pace and limp home. Pretty smart.
I guess if there's a third lesson, it's that the trip isn't over until the last foot is traveled.
June, Lincoln and I sure enjoyed seeing all of you this summer. Thanks for all you are and do.
