Gin
- Dec 12, 2012
- R-31 S
- Echo II (2019)
We have our Ranger Tug 27 (Echo) out of the water for a fresh coat of bottom paint. The boatyard is also going to buff and wax the entire boat (a job I'm having them do, instead of myself, because of oxidation above decks).
The yard welcomes owners to do their own DIY projects while their boats are up on blocks. I have no end of small projects, but most are as easy or easier to do with the boat in its slip. Still, while it is on blocks, I want to take advantage of that.
My list of things to check/do while it is out of the water has included:
Question #2: Does anyone know a good way to flush out the water system without working the pump to death? This will be done back at the dock, but as long as I'm asking questions . . . I leave the fresh water tank and system dry as possible during the winter. I don't fill it with pink stuff (Portland doesn't get that cold usually, and I keep heat on the boat and have a bilge heater). In the spring I fill the tank with water and a strong dose of chlorine, run it through the lines, let it sit several hours to a day in the tank and the lines, then run all that out of the system. Then I give it a fresh fill (or two) and run it through to get all the chlorine out. That is a lot of pumping for the regular pump. I've wondered if there is a way to take a water line off (say, back by the water heater) and somehow do a gravity feed out or use an auxiliary 120v pump of some kind to get the bulk of the water out of the tank without taxing the regular pump so heavily. Anyone done something like that?
Thanks in advance for any and all ideas on both questions.
- Gini
- - General condition of underside of hull (checked and looks good)
- Prop (also checked and looks good)
- Anodes (replaced late last fall; still good)
- Flush cockpit drain lines / check & clean scuppers (haven't done that before - saw it in an older thread)
- Gini
