Universal Pumpout Fitting
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
I have not had to use pumpout on my boat yet. Will I need a universal pumpout fitting or will it work without?
thanks,
If you are pumping out at most salt water marinas in Washington state or in BC, they use a tapered rubber end that will fit your waste port. No other adapter is needed.
Here’s an example that has a rubber tapered end with a rubber cap to minimize spillage
https://www.edsonpumps.com/pumpout-nozz ... qc-150-sg/
If you are at a fresh water marina they may only have a banjo fitting on the end of the pump out hose that needs an adapter.
See my earlier post on how to make an pump out adapter to fit a banjo fitting.
viewtopic.php?f=2&t=6223&p=107175&hilit=Pump+out+adapter#p107175
I highly recommend getting an adapter that screws into your boat. You can get one free at many marinas or contact Aaron Barnett, pumpouts@uw.edu. The tapered nozzles will work fine, but one shift of your boat or your arm will result in a messy situation (don't ask how I know).
You can buy something like this: https://www.fisheriessupply.com/sealand ... ut-adapter
I haven't pumped out my Tug yet either (our marina will do it slipside for $25), but on prior boats I never had an adapter, and never had a spill either... But I suppose putting that in a forum post is probably tempting fate :lol:
Here is what I use on my 31CB — works great!
