rackline
- Oct 30, 2016
- C-288 C
- FMLT1912K809
- Non-Fluid Motion Model
- 17' Finestkind, previous 35' Friendship Sloop
- Headway
I'm electrically challenged and curious if this panel would be a "plug and play" upgrade for the Kyocera 130 W panel on my 2009 Ranger 29. For $75 it seems like an inexpensive way to significantly increase the solar output. https://www.ebay.com/itm/Sunpower-SPR210-WHT-U-Solar-Panel-Ready-To-Ship-/264277662499 Comments on one site state that the increased output for the size is because it requires positive grounding. So, concerns are Positive Grounding, is the output ok for existing Morningstar Duo Controller, and does it look like an easy connection to the existing wiring at the roof rack?
Here's a link to the full datasheet:
http://static1.squarespace.com/stat...0/Datasheet-SPR-230-WHT-U.pdf?format=original
Thanks for any thoughts!
Chris
Chris
