I would like to upgrade my water intake strainer on my 2010 Ranger 21EC. The factory installation on my Yanmar is a fairly small Jabsco strainer located at or below waterline just under the engine on the starboard side. The quality and small size of the strainer has me a little worried and another Tugnuts member with a newer Ranger 21EC has a Vetus 140 strainer mounted on the panel between the engine and the batteries. This strainer is larger capacity, looks easier to open and clean and well made. It is also well above the waterline.
Any other owners of an older 21 do this upgrade? I need to order the strainer and I am not at the boat location right now, so wondering if anyone knows the water hose size for the raw water intake?
Another question...will having the strainer elevated cause an issue with priming the raw water system after boat has been dried out? Would you remove lid and fill with water to help prime? My current setup has a filler at filter designed to connect to a hose for filling winterizer antifreeze and I have used that connected to a hose for priming before (at low pressure of course, to avoid hydrolocking).
Thanks in advance.
Harley
Thanks in advance.
Harley
