Use of solar panel during winter storage
Oldcatboatdude
C-26
FMLT2516H021
Touch of Grey
Hi folks,
I am a Ranger tug neophyte. This is our first time storing our 2021 R25. She is on the hard and hooked to shore power. Should I turn off the solar panel? My feeling is it can help charge the batteries. Dont want to burn out those batteries before get a full season in. What do the experts say?
Bumping delayed post.
The solar panel on my RT25SC has maintained the batteries over the winter (under shrink wrap) for the last 3 winters with no connection to shore power. If you are going to run fans, etc. then you will need shore power. I don’t see any problem leaving the panel connected since you don’t disconnect during the summer when connected to shore power or when you run the boat.
I would say it depends on the charge controller you are using. If it is a smart controller that will manage charging then go ahead and leave it on. I leave my shore charger and solar on all the time.
If you have a dumb/old school solar charge controller that just constantly feeds the battery regardless of condition, then disconnect it and let the shore power charger do the work.
Edit: Just read your post again and saw the boat is a 2021. Assuming its a factory install, I'm sure the factory controller will be smart enough to take care of it without harming the batteries.
When I winterized my boat I usually removed the batteries and would trickle charge once a month if they needed it by joined them together on a bench. This avoids worrying about overcharging or any other issue that may arise. It also is a good periodic maintenance item. At least once a year you are now cleaning all of your connections at the battery terminals and the wire terminals. Is it a bit of extra work? Yes. However, it also gives you an opportunity to clean the battery compartment and check the straps holding the batteries in place as well.
Hello,
As long as you're hooked into shore power you should be in good shape. The solar will be on standby if the battery charge is running.
-Kenny
Thank you all for your responses.
