Using iPhone 6 or 6+ with Fusion Sound System
Spinner
(Former RT31) Current 2003 Nordic Tug 42
Spinner
I am considering upgrading from my old iPhone 4S to the latest models. However, they won't connect to my Fusion system which was built for the older models?
Has anyone tried the Fusion Bluetooth attachment for this purpose?
Or, the Fusion attachment that provides 3 different connector types?
Thanks for any info....
According to a new report, Apple will lock down the NFC chip hidden inside the new iPhone 6 and iPhone 6 Plus smartphones, restricting its use to the simultaneously announced Apple Pay wireless payments system. An Apple representative confirmed the news to CultofMac.com, saying NFC is currently only for use with the in-house software.
The introduction of NFC on the iPhone has been rumored and requested for several years, so to have it arrive, and then find out it’s not all that was hoped for, may come as a blow to some potential iPhone 6 buyers. NFC is used for a wide variety of things, from fast and easy pairing with wireless accessories, to communicating with keyless locks on your house. Most often though, NFC is used for wireless payments, but on the iPhone the only option will be to use Apple’s own system.
Related: How Apple Pay works
It’s hardly a surprise. NFC is being treated in a similar way to the fingerprint sensor introduced on the iPhone 5S. While other smartphone manufacturers have opened up the fingerprint sensor to developers, or added a wealth of functionality to it on the device; Apple’s Touch ID sensor is only used to unlock the phone or approve iTunes payments.
Related: The iPhone 6 Plus is proof Apple is terrified of Samsung
This could change in the future for both the Touch ID and NFC, and Apple may let preferred partners gain access to their capabilities. Regarding NFC, Apple has already teamed up with Starwood hotels so iPhone 6 owners can use their device to unlock hotel doors, which appears to use NFC technology. Early tests like this could pave the way for other companies to take advantage of the iPhone 6’s new feature.
In the meantime, stop dreaming about tapping your iPhone 6 on your wireless speaker to connect the two together, because it’s ability will be strictly limited to Apple Pay.
A quick google search shows that enough people already own 6's and can use their Bluetooth to pair to their stereos. So no worries there. But I've never been able to use the fusion dock because I didn't have a sleeve for the iPhone 5. I thought about just adding a jack off the auxiliary but if there are better ideas Id love to hear them.
Today I use the Aux jack to play music through my R-25's Fusion stereo unit. I use a small iPod the size of a postage stamp at times, my older iPhone 5 and now the iPhone 6+. I find no issue with this at all.
It would be nice if music playback via the Fusion could be done with Bluetooth communication but I've not explored that feature yet. This would remove the use of a wire connection with the Aux jack.
Of course one could use independent Bluetooth speakers and use them in conjunction with the smartphones, iPods etc.
BTW... I had no issue pairing my iPhone 6+ with my Volvo XC70's Sensus system. Worked without issues just like it did for my iPhone 5.
Just buy an iPod Nano or Touch. It will last a lifetime and you will not be upgrading it every time the Next Big Thing comes out in your iPhone. Sync all your music to it, iTunes will recognize it AND your iPhone 6 Plus. Besides that you get to use one of those 35 or 40 sleeves that comes with the Fusion.
I use my iPhone 5s with my Fusion 700 all the time. I sometimes dock it in the main unit using the little lightening connector adaptor. I usually use it via Bluetooth though. I purchased the fusion Bluetooth connector that uses the satellite connector and it works great from everywhere onboard
Can you provide a link for the Fusion Bluetooth connector.... thanks. 🙂
I found this http://www.amazon.com/Fusion-MS-BT100-Bluetooth-Dongle-Marine/dp/B00CUMQU50. Is this same or similar to what you use ?
Thanks all for sharing your experience!!
Capt. Steve...The NFC chip and Apple Pay have absolutely nothing to do with connecting the iPhone 6 to the Fusion system.
It's done either through Bluetooth or via the wired connector as others have explained.
good to know just playing with my iPhone 6 now. Picked it up 30 min ago
The Bluetooth add-on for the Fusion works incredibly well. Any Bluetooth enabled media device connects wirelessly. No more overheating of iPhone either. We can use our iPad now and guests can play their tunes easily.
What is the difference between the Fusion add-on Bluetooth and any other add-on Bluetooth? I had a Bluetooth hands free auxiliary for a car that I plugged into the auxiliary jack on the Fusion and I can not only play iTunes, but also answer may phone and speak hands free.
I added the Fusion Blue Tooth player recently and it works great! Relatively simple to install. I had tried all of the others that plugged in to the phone pin connection, etc and none of them worked.
I had considered upgrading my stereo for better sound, but (maybe I'm dreaming) the sound coming out of the unit is much better. I have an iPhone 6 and it paired easily and plays seamlessly with Pandora, Spotify and my Itunes.
Good luck!
Ok, I have upgraded the Fusion firmware, and have the Bluetooth dongle. It looks like the device plugs into the Sirius radio connection that is only available by removing the unit from the wall.
I can do that, but the line to that connector has to run somewhere other than interfering with the reassembly of the unit. How did you deal with that?
For installing this Fusion Bluetooth add-on, do you have to get behind the unit to install ?
And Mike, on the aux bluetooth you mentioned, is that aux jack located behind the fusion unit? Or is it accessible form the front?
This seems (hopefully) pretty simple. I would like to get away from keeping my phone plugged in full time for Pandora, iTunes, etc
as far as I can tell, it connects behind the unit, therefore my question.
Hi Folks,
I just finished adding bluetooth to the Fusion ip700i stereo that came standard with my 2014 R25SC. Forgive me if any of the following is a re-iteration of what's already been said, but I thought I would put it all in one place for convenience.
Fusion makes two add-on "dongles" (who ever came up with that name?) that connect directly with their head units and provide bluetooth connectivity, similar to many of today's autos. Unfortunately, it does not allow for telephone use, but music and anything else you can hear from the phone, like internet radio, podcasts etc, can be heard through the boat's stereo system.
For the ip700i they recommend the MS-BT200 plugged into the Sirius input jack which, on my boat, is easily accessed at the back of the head unit by peering into the storage compartment (glove box?) next to the stereo. The downside is that you then lose the ability to have an add-on Sirius tuner plugged into that jack.
If you do want the Sirius tuner as well as bluetooth, they recommend their MS-BT100 dongle which plugs into the RCA auxilliary jacks of the head unit instead. The Sirius tuner can then use the dedicated Sirius input, but this is really unnecessary as you'll see below.
Once the connection is made you simply mount the dongle on a convenient flat surface nearby - there's about a 12 to 15 inch lead to the dongle that gives you plenty of mounting flexibility. I simply attached it with a screw high up on the half inch plywood backing of the glove box. Fusion recommends it be as far from any "metalwork" as possible. I have no range issues as it works from anywhere on my 25 footer and even when the phone and I are standing on the dock several feet away.
That's the easy part. Unfortunately, one needs to update the head unit's software before any of this will work. It's not that difficult but adds unneeded complexity to the install. You download the update from the Fusion website onto a flash or thumb drive. The drive plugs into the USB port of your computer. I tried using an Apple desktop and laptop and had no luck accessing the Fusion site. For some reason the site is virtually unusable on an Apple computer - though it does work on an iPad which doesn't do you much good since you can't use a thumbdrive wih an iPad. I had to take the thumb drive to the office and use a Windows PC to get the update transferred. Once the update is on the thumbdrive you plug the drive into the USB input on the back of the stereo. Fusion provides instructions on the website about what to do from there, but again unfortunately, all is not as simple as it seems. I finally did get the head unit updated, but not by following Fusion's instructions which may apply to some earlier hardware/software versions. Wish I could tell you the exact method but I just sat there and pushed buttons till I got it to pair with my phone.
Once it's installed it works great. And by downloading the Sirius app to my iPhone 5 I'm able to get all of Sirius via bluetooth as well. Btw, I've no reason to believe that it won't work just as well with an iPhone 6 or any other bluetooth equipped device.
Sorry for the long winded post. Hope this helps someone.
