barling
- Aug 9, 2019
- C-302 C
- Non-Fluid Motion Model
- Bristol 29.9
- Barling
When we started using the ice maker on our 2014 R31 it worked fine for three days and then stopped. The on /off switch at the 120 switch board had not turned off. We pulled it out and followed the wiring down a hole to an area of the four house batteries where we found a three pronged plug, plugged into a 120 Gfi outlet that we just sitting there. We pressed the reset button and the ice maker turned on and made ice for about two hours and then turned off. Our next plan is to attempt to remove the gri and replace it to see if it was faulty. This needs to work and it is the only thing my wife wants to have working for her cold drinks while at shore power. Is there any possibility the ice maker will run while on generator?
