Hi, all. I recently acquired my first Ranger Tug, a 2012 R-29 @900 hours, Yanmar 6BY2-260 powerplant.
The top item on my squawk sheet was to isolate and resolve an intermittent anomaly in the oil pressure readings whereby the Yanmar engine instrument panel would sometimes show blank oil pressure, and sometimes read implausibly-low pressure upon throttle reduction to idle from cruise power.
Upon studying various threads on this forum I learned that the OEM oil pressure sender is prone to failure and is pricey at approx $275/each, so I decided to set myself to figuring out the source and cross-reference for these pesky overpriced units. (On review of the parts lists for the 4BY and 6BY engines, I found that the same oil sender part number is used, so this information should be useful to owners of either engine.) After removing and inspecting the stamped markings on my original OEM sender, I was able to make a positive identification of its origin, and of a much less expensive replacement unit that remains 100% compatible with the original Yanmar instrumentation.
The oil pressure sender is a fairly standard (in Europe and Asia, at least) VDO unit, bearing the ID marking "32/6" which identifies it as a floating-ground sender without warning contact, 0-10 bar pressure range, 10-180 Ohms, with M14x1.5 mounting threads. The VDO part number for this unit is 360-081-032-006C. You can order this sender from European suppliers for approx. 55 Euros.
If you'd like a convenient replacement for this unit that can be obtained readily from US suppliers, then you can order a VDO 360-043 (ID stamped as 32/14), which is the same unit as the original, but with a 1/8"=27 NPTF mounting thread.
$36 at Fisheries Supply:
https://www.fisheriessupply.com/vdo-gau ... to-150-psi
Sku# 431477.
In order to use this sender in your BY-series engine, you'll need an inexpensive thread adapter: Male M14x1.5-to-Female 1/8"-27 NPTF. The adapter threads into the engine port, and the new sender threads into the adapter. This sender will work with your original instrumentation without any modification.
https://www.amazon.com/Female-Sensor-Ad ... 291&sr=8-6
At these prices, you can replace your intermittent or inop OEM oil pressure sender and stock up another half-dozen spares for less than the cost of one unit packaged in a spiffy Yanmar cardboard box.
Happy tugging!
Sku# 431477.
Happy tugging!
