VBerth perimeter lights do not switch on
baweir
FMLT2734G819
Tir Na nOg
Appears from diagram that this is a single wire app with a 5amp blade fuse. Replaced fuse but no joy.
Next is switch examination. This is on a Ranger 27-OB 2019. Any experience with this to share?
Mine wouldn't come on and I found that the wire, close to the fuse connector, had broken. I just trimmed some off the end and reconnected it.
Hello,
I would remove the switch in question and check the connections to make sure they are connected. If so, test for power going to the switch to ensure you have power. If there is power you can turn on and test for power coming out of the switch. This would eliminate the switch and then would be checking for continuity on the wire in question to make sure there is not a break in the wire. Hope this helps!!
