Volvo D4 Transmission Oil Extraction
Part number on the oil sample pump is 509-7889
I got it from Volvo Penta at the Roche rendezvous a few years back. The oil sample container from pacific power fit the pump. I’m guessing it’s a standard container. You will need to purchase the test kit for mailing the sample in.
You will also need the tubing shown in the picture above too. I don’t remember the diameter but it’s easily available locally. Good rule is to use new tube on every sample. Especially between engine and transmission.
Excellent! Thank you!
+1 for using a new tube on every sample, to avoid cross-contamination.
