Volvo D4 WOT Drop-off
Dcsqatar
R-29 S
Beautiful Red
I have a 2020 R29S with a 300 HP Volvo D4 with about 400 hours. I have tracked wide-open throttle (WOT) over the years as a measure of engine health. Since new and for 4 years in the Pacific Northwest, WOT was always around 3610 rpm. Last year I shipped my boat to the Chesapeake Bay. After a full engine service over the winter, I put her in the water in March. I recorded WOT of 3580 rpm on 30/May and then it continued to drop all season to a low of 3410 on 10/Oct. There also seemed to be a drop in efficiency (e.g., NM/gal). In the PNW, I had routine hull cleaning by divers, but was unable to arrange for that service here on the Chesapeake. What is experience with WOT drop off in general and linkage to hull marine growth in particular? Attached are three photos of my boats hull when recently pulled from the water for winter storage. Doesn't look like much growth to me.
Thanks in advance for any help.
I asked my Marina owner the same question re my D4. He strongly suggest that I get the prop reconditioned and take some pitch out of it. I’m at 3,300 and have a 31cb.
I have a D4 260. I definetly saw improvement after I had the prop reconditioned. My mechanic had a tough time getting it off.
Since its been 12 years I'm having the bottom soda blasted. I think that will make a difference too.
-martin610
Thanks. What exactly is prop reconditioning? Is it possible to determine need for/value of doing by inspecting the prop? What should I expect, and any idea of cost? Is this something I can request from outfit providing engine service, or do a I need to look elsewhere.
I always thought it was a good idea to remove the prop and clean, lube the spline at least once a year during haul out?
Most marine mechanics can do this work if they have prop pulling tools.
Props can get out of spec with very light grounding, or even just use under load. I don't think anyone can eyeball it. It's good to get it off once in a while to make sure you can get it off god forbid it gets mangled.
I paid 280 dollars to have it reconditioned last time I did it.
-martin610
A prop shop will have pitch blocks for pretty much any propeller. They can use them to see if your propeller blades are within specifications and if bent then adjust them back into shape. A bent blade can certainly account for reduced efficiency and rpm.
even with diving my WOT drops over the life of the paint. definitely WOT drops due to a dirty hull
also don't forget weight on the boat. fuel, water, gear, people.
I am not so meticulous about recording my WOT throttle numbers, but at commissioning my D4-260 was at ~3500 RPM WOT. I was seeing numbers in the 3200-3300 range at one point and talked to our dealer, who asked about the bottom, ie how clean it was. I checked WOT again after the next bottom cleaning and it was back to around 3400. I attribute the rest of the drop to weight added to the boat since we've owned it - we were fairly light at commissioning.
Also, we're in DC as well at Columbia Island Marina. There are some places around here where you can get a quick haul and a power wash of the bottom.
Copied and pasted.
Why Boats Perform Differently in Salt Water vs. Fresh water
If you've ever taken the same boat from a lake to the ocean and thought, "This feels different," you're not imagining things. There are subtle yet significant differences in the way a boat behaves depending on whether it's in salt water or fresh. These changes are largely due to physical properties like density, viscosity, and buoyancy-and they influence everything from fuel economy to handling.
Understanding these factors can help boat owners and captains better anticipate how their vessel will perform, depending on the body of water they're in.
Side by side of boats, one on lake and one on ocean
Density: Seawater Gives You a Lift
Freshwater has a density of about 1.000 g/cm³ at 20°C (68°F). Seawater, thanks to its roughly 3.5% salt and mineral content, is denser-around 1.025 to 1.030 g/cm³ at the same temperature. That small change-just 2.5 to 3%-makes a noticeable difference in how a boat floats.
Boats sit higher in saltwater than in freshwater. This means less hull is submerged, which generally reduces hydrodynamic drag. That reduced drag can result in better fuel efficiency and slightly higher speed. It can also change the trim and balance of the boat, especially if the weight distribution was optimized for freshwater.
When a boat floats higher in saltwater, the reduction in wetted surface area not only improves performance but also affects stability. That's why careful operators often recalibrate trim tabs or ballast slightly when transitioning from lake to ocean.
Viscosity: Thicker Than Water... Barely
Viscosity is a fluid's resistance to flow. It influences how easily water slides past the hull and how well the propeller can push against it. At 20°C, freshwater has a dynamic viscosity of about 1.002 centipoise (cP). Seawater is slightly more viscous, at around 1.08 to 1.20 cP, depending on temperature and salinity.
While that difference might seem trivial, it has a measurable impact at high speeds or in finely tuned propulsion systems. Higher viscosity means slightly more friction along the hull. But it also improves propeller grip, especially when pushing heavier boats or accelerating from a stop.
As a result, many boaters notice that their vessel responds faster to throttle in saltwater than in freshwater, particularly with properly pitched propellers
