dbsea
- Oct 1, 2021
- R-23 (Outboard)
- HALCYON
I spent the nite on my boat in Andrew’s Bay due to contracting Omicron (yes, triple vaxxed). When I woke up this AM, it was obviously very foggy and cold. I decided to start the engine to heat the water heater and recharge the batteries from overnight usage and running the inverter for coffee. When I tried to crank the engine, it threw an error on the Volvo screen that there was a sensor failure, and the Garmin screen said “Water in Fuel” in the warnings list. The engine did not start on that try. My anxiety level spiked. I cranked the engine again after dismissing the warning and it started as normal, and I ran it for 20 minutes. I turned it off and turned off the ignition, and restarted. All warnings went away.
Is this all a symptom of the very cold foggy morning, or something I should be looking at, and if the latter, what am I looking for?
Thanks…
Thanks…
