henningbuus
- Apr 26, 2018
- Everett Washington
- C-302 SC
- FMLT3131C616
- SALTY old DANES
When trying to start my Cutwater 30CB engine with the parallel switch on, the battery power was insufficient to crank the engine. It would make half turn and stop. I switched the starter battery with the thruster battery, and it started with no problems. The next day I had the same problem, so I switched the batteries again and the engine started with no problems.
To me it looks like the battery that is connected to the engine gets drained over time, and the parallel switch is not connecting all the batteries together. When not in use I always turn the engine and thruster battery switches to off, but the battery connected to the engine is still low after some time. I noticed that the voltmeter showing the engine battery will fluctuate between 11.8 and 12.4 volts every 1-2 seconds when the engine is not running and the engine battery switch off. That indicates that something is turning on and off, and it might be the cause of the battery draining, but what could that be? I wonder if it could be a problem with the charging relay?
