plewis
- Aug 12, 2016
- C-288 C
- Last Chance
I have on a few occasions stopped my Volvo D4 engine using the start/stop button but then failed to push the ignition switch to turn it off. The most obvious result of this senior moment is near dead battery next time I use the boat. Without offering my opinion on the wisdom of the two step process to turn off the engine, I'm just wondering - has any one else had this problem? Also, my hope was that if the e-key/fob was far enough away from the boat, the ignition would turn off, but this doesn't happen. In fact, the e-key doesn't appear to do anything at all. It isn't even required to start the engine. In an effort to fix it, I was able to deregister and re-register the fob via menu prompts, but it still doesn't have any effect. What am I missing?
