Captain Mike
- Aug 9, 2020
- C-248 C
2016 25 classic with 150hp volvo penta
Engine power problem. Engine is running fine and works perfect for about 15 - 45 minutes, then for some reason, the engine power drops off and continues to run well but only with 2000rpm as max speed.
I thought it was a fuel issue so changed all of the filters. then opened up the fuel tank to confirm the fuel is clean and that the fuel tank siphon filter was clean.
No error codes come up.
My mechanic is not a volvo dealer so he does not have access to the computer codes. He is reaching out to others to see what they think.
This is my attempt to find out if anyone else has experianced this problem and what might be causing it.
thank you
thank you
