In the last 10 months I have heard about 3 RT25SCs having a reverse gear failure, all with Volvo Penta engines. Several years ago Cummings Diesels had a problem with their reverse gears that were made by ZF, same manufacture as the Volvo Penta reverse gears. It turns out that Cummings ZF failures were due to an insufficient toritional interface between the engine and reverse gear. This interface smooths out the bumps comming from the engine into the transmission. As I understand Cummings corrected the problem. I am wondering if Volvo Penta has a similar problem. It would be interesting to hear from the Tugnuts on who has had a transmission failure, the time on the engine and the make of the engine. I will start:
Failure occured September 2021, Volvo Penta D3 150i-G and 495 hours on engine.
Thanks for your reply
