For those of you planning to put your boat away for an extended period, we have a trick to help prepare your Wallas stove or furnace for storage:
Start the Wallas device and let it run until it has come fully up to temperature. If you have a day tank system (most common for stoves and stove/heaters), unscrew the tank cap and pull the fuel line out of the tank. Let the system run until it stops for lack of fuel. This can take a few minutes.
If you have a system plumbed directly into the main fuel tank, then find the fuel filter (small and yellow) and disconnect the fuel line at that point (again, while the unit is running). Let the system run until it stops for lack of fuel.
Check your fuel filter to see if looks clogged or discolored. Contact us if you have any questions about it.
Once the system has stopped, reconnect your fuel line or reinstall the filter and screw the cap back on.
This procedure will purge the Wallas device of fuel. You will need to let the system re-prime when you start up again.
This process will prevent fuel from gelling inside the device during long term storage.
Please let us know if we can be of assistance. 1-888-606-6665, M-F, 9-5 PT
Thanks for using Wallas!
Doug at Scan Marine
Doug at Scan Marine
