Waste tank 2018 R27
Matty
IN THE FALL (2018)
My orientation was a bit short due to late in the day delivery so simple question while waiting for manual.
Where is the waste tank located? Is there a y valve for mercerator? Where is it located?
Hey there Matty,
Please check the technical bulletins section. I am going to post a drawing I did for the new 27. Almost finished with that manual. It will help answer all of your questions pertaining to this.
Thank you!
Andrew Custis":2rl7no9n said:
Hey there Matty,
Thank you!
Thank you for the preliminary drawings for the 27OB, looking forward to the full manual. You wouldn't happen to have drawings for the raw water system ready that you could post?
Thanks andrew. I am so grateful for your quick response i will not mention the final manual. I am sure you are working diligently on it.
Andrew Custis":2f6yum0f said:
Hey there Matty,
Thank you!
Thank you very much for these PDF scanned files. Much appreciated. 😀
Matty: Note that the only tank that is visible is the aft section. of the fuel tank (and of course the hot water tank), The waste/holding and fresh water tanks are completely hidden from sight. They both sit forward of the large fuel tank's center line and immediately aft of the forward bulkhead/cross-stringer.
Drawings provided the help I needed. My son and I went out in the ocean the proper distance and emptied the tank to be sure I had that system down and all went well. On to the next learning experience.
