Pete
- Jul 11, 2012
- C-28
- Stella B
Pumped out the waste tank on my new 27 for the first time yesterday. The cap is located directly under the stern rail with about 8 inches of clearance and I was unable to get the hose fitting/suction cup vertical above the outlet. I was able to get an effective seal and pump out successfully but with the variation in pump out designs I've encountered I can envisage, sooner or later, being stuck with a full tank that I can't empty.
I assume this is the same location as older Rangers. Has it proven to be a problem? I'll also check with the factory.
Pete
Pete
