Water pump connector and O-ring
Scuba Too
R-29 CB
Blue Honu
My aqua jet for fresh water is leaking at the connector on the output side (I have a 2017 R29 CB). Does anyone know the size of the O-ring it uses?
Can't tell you the size but, I bought an Aquajet 1/2" barb off Amazon for $5 to rig up a system to blow out my water lines. Might be just as easy to buy the fitting and pop the o ring off.
If the leak isn’t too bad try a few wraps of plumbers tape around the o-ring. That worked for me.
They sell O-rings at any hardware store! Take the old one out and they can match it to a new one. If unable or don't have the old one the inlet side should be the same size. Using tape to repair a water leak is what many would call a minority fix! Bob
