capnlmk
- Aug 15, 2015
- C-26
- FMLR2505F516
- Scuttlebutt
When we dewinterized this spring and refilled the water tank on my 2016 R25SC, the water pump didn't seem to be functioning properly. It made more noise than usual, with considerable vibration and the hot and cold water pressure in the cabin was little more than a thin stream.
Thinking the pump might not have primed properly after being dry all winter, we did the trick of stuffing a towel around the water fill port and then forcing water into the tank, in an effort to force water into the pump. Tried this approach a couple of times, but it didn't make any difference.
So, we do have cabin water, both hot and cold, but with a lot of pump noise and not much pressure. I am reluctant to run the pump, not wanting to harm it -- so I leave the pressure water turned off. Suggestions for what we should do next would be most appreciated.
