A timely post for me. I, too, am wondering how to check the water tank gauge on an R27.
Mine has worked flawlessly for three years. Until two days ago. I discovered it is stuck in the full position. To try to dislodge it, I emptied the tank. The gauge still was reading full. I pulled the fuse, and the needle on the gauge dropped to empty (not surprisingly). I put the fuse back in, and the needle pegged over to full again. I then re-filled the tank. I suspect when I start using the water, the needle will stay put.
Near as I can tell, the only way to get to the water tank on an R27 is to cut into the floor in the V-berth area. I'm hoping I'm wrong and there is an easier way.
Anyone on the forum know? Kenny? Andrew? Or someone from the factory, can you advise?
- Gini
