Water under stove
pugtug613
Pugs Tug
Just got back from our Labor Day weekend on the hook. When cleaning up we noticed the cabinet under the stove on our R27 was wet. It is next to the head and we showered over the weekend. It rained a little bit. We did plenty of dishes. I did fill the tanks before we left. I made sure the tank was full, I filled the tank until the water came out of the vent. The vent is in that area. Any ideas?
Chester
The Pug's Tug
Several possible sources. You will have to try to narrow it down one at a time. Check your water clamps especially at the connection at the curb water connection, check the connections at the thru hulls, check the bezels at the small lights along the outside walkway. I doubt it was water from the head since that area is all moulded. If anything water would leak out from the door onto the floor before it would go under the stove.
If it is a water leak from the water system you should hear the pump cycling on and off occasionally while the water is off, but power on to the pump.
Keep us posted.
I did notice water on the floor after a shower. We have to "adjust" our shower curtain. Good point about the pump cycling. It doesn't. I will get my special wrench and go thru the clamps. I'm leaning toward the shower.
Our 27 had a very slow leak and the pump did not run noticeably. It was the through hull water connection behind the stove that had came apart. I pugged the tube and the problem was solved.
