Webasto AC Error Code 1
fmstuart
FML32C19L920
Cutwater CB32 (not available on the drop down list
Crimson Tide
We have a 2020 CW 32CB, and the galley AC is throwing an E1 error code. This indicates a water flow error, I think. Anyone else had this and fixed the problem?
Forrest Stuart
I have a C28 so the set up is different. Flow errors are tripped when the system is clogged and the pump loses prime. Check strainer first and work from there. You may need to back flush your system from the outlet. If you’re in saltwater, you may have some growth that the salt guys can chime in on.
The strainer was full of caked on gunk. We cleaned it and back flushed it from the strainer cap. There was no other way to back flush, but if there is a built-in way, please inform me. The discharge was still weak, but it has improved overnight. I still feel like there needs to be a good flushing.
Thanks for your input.
Forrest Stuart
