stwendl
- Aug 11, 2015
- C-28
- FMLT2719J516
- Cataleya
There have been several threads on this subject in previous posts. This is in regard to a 2016 R27.
I have stuck several clearing items into those opening to make sure nothing is obstructing the passage. But I noticed
in the starboard aft corner, where the transducer is located, standing water that does not seem to want to drain.
Today I stuck a pencil cam into those openings to see whats going on. The weep holes going aft from the engine room, one into the stern thruster cavity, and the other one into a similar cavity at the stbd side of the rudder, seem to be free.
Then there is the said area of the transducer. This weep hole seems to lead to a cavity underneath the panel that covers the floor of the stbd storage locker where the water heater, charger, inverter are located. There seems to be a side weep hole a few inches aft of the thru hull strainer. It seems to be partially obstructed what looks like fiberglass webbing (see my album). I presume there is a similar arrangement at the port side
Would be nice to get some detailed pictures posted from the factory what the structure under the deck looks like before the cockpit is mated with the hull to understand how water is draining from those areas. Perhaps inspection openings would be a good idea.
