DBBRanger
- Mar 31, 2013
- R-25 Classic
- Still Crazy
I developed a leak in the forward cabin aft of one of the stanchions - the mouse fur was wet on the hull and the water had drained down onto the shelf behind the bolster cushions. I took off the ceiling mouse fur/panel in order to see where the water was coming from. I assumed it was coming through the stanchion base plate, but I could not verify it by spraying water on it. I was able to pull the mouse fur back enough such that I had a clear look at the area all along the hull/cabin interface. I then thought it must be coming in the screws connecting the cabin to the hull, but again no evidence there. Yet as I was spraying water on the outside, water was still wetting the mouse fur. To make a long story even longer, it turns out there are two pin holes in the hull fiberglass that the water was weeping though - not through holes from the outside in, just on the inside. As shown here:
The weeping did not stop when I stopped spraying. Apparently, water is getting into the fiberglass above this area most probably through a hull/cabin screw (which BTW are not the screws holding the rub rail on - they are under the rub rail). It then must seep down THROUGH the fiberglass until it reaches the pin holes and exits into the mouse fur. Is this possible? I didn't think fiberglass was porous like that. Can there be another explanation?
