BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
The wet compartment floor and soft wood is a common issue with the Ranger and Cutwater cockpit drains. This design has flaws. IF the boat were to sit perfectly level fwd and aft, port and starboard. IF the deck drains were installed with a gradual fall no low spots. IF the drain hoses are completely clean with no obstructions. IF the Screens at the deck drains are removed or cleaned. IF the deck hatches have good seals installed and are sealing properly. IF the deck latches were properly installed with sealant and the o-rings in the latches are in good condition. The design has a chance of working as a self bailing cockpit and the compartments will stay dry.
I have a full enclosure and in a heavy rain I have seen water over flow into my starboard compartment. I have tried to cover all the (IF'S) stated above but the water makes its way in at the corner of the trough opposite the the drain. I am proactive at making sure I dry the compartment when water leaks into it. I am also proactive at maintaining the limber holes that drains water from these side compartments to the center bilge.
The wood used in these compartments seems to be a good quality plywood (I assume marine grade but I don't know) The top side of the wood is sealed with Gelcoat. The bottom side is not sealed. The ventilation in these compartments is limited, other than the gaps between the hull and the cockpit liner. The gaps that allow air in and out can be obstructed by wire looms, hose runs, and equipment being stored in the compartments. If water and moisture gets into theses compartments and it is not dried out the wood will rot in a short period of time. Poor drainage and no ventilation in a boat with wood components is a combination for rot and mold.
It's a boat! You can't do anything about water and moisture! You can't do anything about the unsealed wood in the bilge unless you remove it. You can maintain all the "IF'S" . Maintain the limber holes by confirming they are not plugged. Make sure there is good air flow in and out of the compartments. You have a fighting chance of the compartments staying dry and reducing the chance of rot.
Maintaining the boat to float level is a good thing to do but all I can say to that is GOOD LUCK! An 8'6" beam boat is very sensitive to weight. Even a 10' beam boat is. Sliding a cooler from one side of the boat to the other can throw it off.
"Ventilation" I have beat this dead horse on TugNuts for a long time. Sorry for my passion on the subject. A boat built without a ventilation system can work. That is proven Ranger Tugs and Cutwaters operate with out a ventilation system installed. Marine ventilation is a necessity for the performance of engines and other equipment. Ventilation systems both move the air and equalize humidity levels inside and outside the boat. I would assume when the design engineers at Fluid Motion decided that the air gaps around the cockpit would be adequate. The calculations proved enough air flow to operate the engines, generators, battery ventilation and equalize the humidity levels inside and outside the boat.( I assume) The engineers concluded "we don't need to put ventilation is our boats. ABYC states diesel powered boats can operate safely without ventilation. The air requirements to run the engines is met." They must have been right because they have built a lot of boats and no one has had an issue ???
Did the design engineers figure in the wire loom runs and hose runs that are installed between the liner and the hull ? Does this disrupt air flow? Were calculations made for the Ranger owner or Cutwater owner that have extra gear on board using all the available space in the storage compartments to store items. Does this impede air flow? If water and moisture gets into the compartments will the air move enough to equalize humidity levels? With the generator operating at close to 210 degrees will the air in the compartment be cool enough to operate at design. Will the engine now have enough air flow to operate properly and compartment temperatures stay at levels recommended by ABYC and Volvo or Yanmar? I assume they did.
My C26 had issues with high compartment temperatures ( I have mentioned this a few times 😀 ) I was able to resolve this with adding extra ventilation to the boat and install two exhaust blowers. I copied the design from looking at many manufactures, Nordic Tug, Helmsman, American Tug, Back Cove, Sabre, Bayliner Motor yachts...... If its a power boat it has a ventilation system installed. This system not only helps maintain engine compartment temperature. It also helps with odors, moisture, mold, mildew and soot.
Rangers and Cutwaters owner's boats that I have boarded. Although most do not express the need for better ventilation there is evidence that it would help. I have seen mildew, wet compartments, area's of corrosion and rust, soot, smelled odors ( not talking about waste tank but ventilation can help with that too). I have talked to owners that have soot stains in the living spaces. Generator operation issues, ( many carry capacitors on board because they fail, burn up literally) Install larger fuse capacities ,circuit board issues, sensor failures many of theses issues can be caused from many things but one of many things includes operating in a high temperature compartment.
I was on board a Ranger Tug a few months ago that had a considerable amount of soot in the engine compartment. The Tug owner was asking about it. My first thought was he had a exhaust leak.The exhaust was leaking into the compartment. The only way out is through the engine ( intake ) there is no other way for it to be exhausted. (No ventilation) I asked if he had ever had issues with the generator? He stated yes the capacitors seem to fail. We looked at the ventilation install for the generator and it was installed backward sucking warm air from the engine compartment into the generator box and a vent hose came off the box back into the compartment. I question that, It pulls engine compartment temperature (120F to 140F air) into the box to cool a generator that operates at 210F and then expels this air back into the engine compartment? That is possibly part of the problem poor ventilation in the compartment? We then looked closer at where the possible exhaust leak was coming from. It appeared that the soot was being drawn into the engine compartment from the deck drains ???? There are two drains in the trough for the the engine compartments deck hatch. Both of these drains had a heavy build up of soot. The area around the drains leading into the compartment had the heaviest concentration of soot. I advised to troubleshoot this clean the area and tape over the drains temporally to see if this reduces the soot. If it does then inspect the flaps mounted in the transom drains. Open the storage areas up and make sure that there is enough open area to get air into the compartment for better engine air flow. If there still was an issue I would advise installing more engine compartment ventilation.
My opinion. The ventilation system was marginal at best. The Ranger tug had many cruising hours on it. The Tug owners were using the boat for what it was designed to do Cruise. They had no complaints with operation and really liked the boat. It was well maintained. They had a lot of gear on board and storage compartment were full. I believe the engine air requirement for operation was greater than what could be pulled in around the gaps in the cockpit. This created a higher then normal depression in the engine compartment. Some of the exhaust coming out of the side exhaust would trap under the swim platform and this exhaust was sucked into the drain scuppers and pulled into the engine compartment.
Ventilation in a boat is more than keeping the compartment temperature at recommended levels, keeping compartments ventilated to equalize the humidity levels inside and outside the boat, maintaining enough air flow for proper combustion of the engine and helping to reduce compartment odors. A properly designed ventilation system is to do all of theses things.
I personally do not agree with the design that Fluid Motion uses. They have built a lot of boats with a lot of satisfied customers. If there is any merit to my post I hope it is this. Understand what the engine requirements are for temperature and air needed for induction and operation. Understand where this air is coming from. Know that if areas get wet or there is high moisture in the compartments it isn't going to leave without doing something about it. If there are a lot of items stored in the compartments make sure that the items are not blocking air flow.
