I believe Garmin makes another transducer the GT8 that has a somewhat similar idea. You glue a foam ring (that they supply) to the hull, then fill the ring with epoxy to ~1/2 inch depth then press the transducer into that. The GT8 has a 250W rating compared to the 600W rating of our GT15 transducers. I don't know if the GT15 would work well using that method but you might try that although if it didn't work, then not sure you could recover the transducer to try another approach. By the way, I'm curious as to where the leak occurs, I've heard other tugnuts have some complaints regarding leakage, is it around the threads where the transducer connects to the cup or at the base where the cup is bonded to the hull.
