What is it?
Doug in Williamsburg
C-248 C
FMLT2529J809
Carol B
Hi all,
I am creating this topic for anything you cannot identify which is on your tug.
I found a white wedge-shaped item loose in the bilge of the engine compartment Can anyone tell me what it is?
--Doug
Here is another mystery. This tool was loose in the bottom of the briefcase which held all the equipment manuals. I do not know which piece of equipment it goes with.
Can anyone help?
--Doug
Can anyone help?
--Doug
This tool is for your sink faucet to tighten to keep from dripping.
Picture #2 would be a wrench that fits the top adjusting ring on the pullout faucet.
Howard
Pic #1 looks like a left handed diesel smoke shifter.... I could be wrong however. 😀
Eric
Picture 1 may be one of the wedges that are slid under the thru hull valves with a 90 degree off-set. They provide support if a heavy weight is accidently placed on the valve.
Agree with Kaiserwe on pic #1. These little blocks are under the seacock for the generator and a/c, to provide support. Don't ask me why they are only "tie-wrapped" in place Doug. :?
Thanks guys and gals.
Your responses have been all very helpful.
I hope some other owners will continue to use this discussion for "widgets" on their boats.
--Doug
The wedges that are slid under the thru hull valves were done in response to a magazine article that criticized the 90 degree sea-cocks.
Don't know if the newer models were changed but the older ones were retrofitted.
Tool in the 2nd photo also is used to install or remove the flag pole.
