I use two of these - Command Broom Gripper DFGPDQ, available in pairs and sets of 4 from Amazon. (Also in some dept. stores) which mount on clean fiberglass and grip the pole at both the larger diameter near the handle and the slightly smaller diameter of the inner tube near the hook. I put them on the outer cabin wall in a vertical position and mounted so the handle on the lower end rests on the floor (actually on the cockpit starboard step). This allows the weight to be carried by the step instead of the clips. You just grab and pull straight out to release, reverse to stow. On the R25, I put it about three inches to starboard of the cabin door latch so it does not interfere with door swing. Works great. No holes drilled. Put it in the cave while trailering. Clean surfaces with rubbing or denatured alcohol before mounting. Can send you a photo if you want by email.
