I encountered “The Screw from Hell”!
Here is an email I sent to Bennett Marine:
——————————- QUOTE——————
Mr. Thomas,
Thank you for your reply.
What should have been a routine operation to top-up the fluid reservoir became a nightmare due to “The Screw from Hell”.
I am referring to the small sheetmetal screw with a Phillips head, item 12 in your schematic of the fluid pump assembly.
For some reason, whoever tightened this screw in your factory used a power tool that maxed the force.
As a result, it was impossible for me to remove this screw with a Phillips screwdriver without stripping the screw head.
I ended up having to use a DeWalt power tool and buying special sheet metal drill bits to remove this screw. There is absolutely no reason to tighten the screw to this extent - and it costs this customer hours of unnecessary work and research on the Ranger tugs user forum.
I recommend that you pass this comment on to the individual or individuals who may be concerned.
Regards,
Claus Jensen
——————- Reply from Bennett ——————
Mr. Jensen,
I’m very sorry to hear about the nightmare you had in removing the LEXAN COVER SCREW.
Our V-351 HYDRAULIC POWER UNITS are shipped with the LEXAN COVER in place over the unit, but the SCREW is taped to the inside of the LEXAN COVER. We do not install the SCREW, because the first thing you have to do when you open the V351 HYDRAULIC POWER UNIT box is fill the FLUID RESERVOIR with ATF. The SCREW is installed after that by the INSTALLER/TECH on the job using a standard screwdriver vs. a powered one.
We look forward to your reply.
Regards,
M.J. Thomas
Client Services
Bennett Marine
A Division of Yamaha Marine Systems, Inc
So, I guess the installation was done by someone at the Ranger Tug facility...
End of story
