allanrs74@gmail.com
- Mar 1, 2018
- C-28
- Cherokee Rose
I have a 2016 R-27 Classic with a blue hull, tan topsides and white roof over the cabin. I have mastered keeping the blue hull gel coat looking good with periodic buffing and waxing. But I have not figured out how to do the same with the white gel coat surface of the roof. With the many curves, elevation changes, handrails, etc there is little flat surface where usual buffers can be used to remove oxidation. The surface is showing oxidation and after waxing does not look very good. I've avoided doing anything about it as it is somewhat out of sight. But when you look closely it does not look nearly as good as the other surfaces. Has anyone figured out how to maintain this surface? Are there any tricks that can help keep this surface looking good?
I look forward to hearing others thoughts. Thanks Bob A
