serpa4
- Jun 20, 2020
- R-23 (Sterndrive)
- FMLC3051D818
- DayLo
I was looking at the C30 wiring diagram. I have a C30 with a generator.
Why do we have a separate thruster/generator battery?
I get that it is for starting the generator and running the thrusters.
However, if you re-wire for the house bank, you'd gain 100Ah of capacity or 25% more house capacity.
My logic, tell me if I'm wrong.
The generator can easily start off the 4 (same G31) batteries as the single (G31) thruster/generator battery.
If the engine battery goes dead, you start with the house batteries using the combining switch already there in the boat.
If the house batteries go dead, then you cannot start the generator. However, you can start the engine and it will charge all batteries from the 115amp alternator. Even if you only need to run the engine long enough to charge the house battery enough to start the generator. That is IF you kill the house enough not to start the generator.
If you are using the thrusters, then the engine is highly likely to be running and providing charging to the house batteries running the thruster. And there is 500Ah of house capacity with 5 group 31 batteries. This should never be an issue. Maybe you don't want to kill the house batteries with the thruster, but how would you use entire 500Ah of capacity with the thrusters? Not even remotely possible (especially with the engine running anyways).
Why not just move the thruster battery to the house and also ditch a battery combiner switch while you are at it?
On a separate note. Someday I'll jump to lithium.
I could do 2 100Ah battleborn batteries which are rated to 100% DoD. This is the same as 4x 100Ah AGM G31 drained to 50% DoD.
Then, I can find Lithium start batteries rated at 70Ah and 1200CCA for the Volvo D6. This single battery is about 20lbs.
3x Lithium house: 3x30lbs=90lbs and 300Ah usable (2x house +1 more for thruster if it is even needed).
1x Lithium start: 1x20lbs=70Ah for engine at 1200CCA
Lithium weight: 90+20= 110 lbs
AGM:
4 house at 50Ah usable = 200Ah
6 x Group 31=6x80lbs=480lbs
Weight savings: 370 lbs or the weight of a dinghy and engine and davits and still be ahead by 110 lbs.
AGM:
