captd
- Nov 23, 2008
- C-24 C
- FMLT2528I809
- Non-Fluid Motion Model
- 27 ft. 1979 Sports Craft
- Lucky Finagin
By drilling a 4 1/2 inch hole in the floor we discovered a leak where the water fill goes into the tank. The hose fitting was badly cross threaded. The tank sets down to low for the fitting to clear. By reducing the fill line from 1 1/2 " to 1" may fix the problem. All Rangers must have cross threads on this tank set up. It is impossible to redo the plumbing without cross threading. Once this is done we will go to the city water connector that leaks.
The factory is stepping up to the plate and having it repaired. 1st Mate Yacht Services is doing the job. Right here in St. Augustine. Jim is up to the job. He has the fitting in and hooking it up. Thumbs up!!!!!!! 😀
PS this is a live report. News as it is happening.
to be continued
captd
to be continued
captd
