SLyle01
- Mar 22, 2019
- C-28
- Aurelia
Due to frequent jamming of chain in the gypsy (deploying, & especially retrieving), we installed an anchor swivel-shackle. Decided to drop all 50' of chain and 40-50' of rode in a 100'+ deep spot to let the chain/rode 'unkink/untwist'.
Once deployed, windlass would not retrieve AT ALL, even though anchor was just dangling free -off bottom. Noted no clutch slipping at all, no jamming in gypsy, no overheat and no electrical issue, since windlass worked OK once load was manually reduced by hand. Load seemed too heavy for the Lewmar unit. After trying for 10 mins. to no avail, we even considered cutting line and RTB! Eventually it took 2 people another 15 mins. to manually retrieve ALL that rode, hand-over-hand, taking up slack with windlass, and clearing anchor-locker frequently. That process is dangerous and uncomfortable.
Chain did appear to be 'unkinked' and better-aligned going into the gypsy when windlass finally began to retrieve the last 30' or so -operating normally, 'as expected'. However, we will not be comfortable using anchor until windlass issue is resolved. NOTE: Remote windlass operation in cabin is useless, since anchor-locker must be frequently cleared below gypsy to avoid stoppage.
Suspect the lEWMAR is faulty/inadequate, since many folks on TugNuts responded that they have NO problems with their windlasses, even with heavier and deeper anchorages.
Please advise, thanks.
