window latch on R-29, replacement
AlamedaKen
C-288 C
FMLT2929C010
Scuffy
The latch on a sliding window on our 2010 R-29 came off and as luck would have it fell into the water. I need to find a replacement. Are these available from the factory or do I need to look to a third party supplier?
AlamedaKen
I'd suggest starting with Richard at RT. He can be reached at parts@rangertugs.com or call 253-839-5213. If he does not have what you'e looking for he'll get you in the right direction.
Jim
I’ll assume your latch is brown and like the one on our 2009 R25. From a prior post:
Just before the 2016 Rendezvous, the window latch next to the helm station fell off. At the Rendezvous, Ranger Tugs staff applied the magic fix.
They used black Sikaflex 291 adhesive.
First step was to clean off all old adhesive residue from both the latch and window.
The correct position on the window was outlined with green masking tape.
Then the Sikaflex 291 was liberally applied to both sides of the window latch.
Next the latch was positioned and clamped with a large wood clamp for a minimum of one hour.
(We left the clamp on for four hours just to be sure.)
Then the excess adhesive was trimmed and removed with a razor.
After three days of very heavy use the latch seems to be holding in place with no issues!
Thanks to Andrew, Ralf and the Ranger Tug repair team for the solution to this fairly common issue!
I also contacted Diamond Sea Glaze for two spare latches just in case. Part Reference Number: HW-LS5564 Hande, D15, Painted LP - R.BOM
They were $14.75 each plus shipping. Here's the contact info:
Danielle Bentley
Parts Sales Administrator
AdvanTec Global Innovations
Direct +1.778.726.0150
