RobMcClain
- Sep 29, 2013
- PNW
- C-30 S
- FML30C02J122
- Freedom 3.0
During the winter season one of the heaters I operate inside my C-30 is a True North by Caframo. It’s the one with the anti-freeze setting so it goes on when the temp drops to roughly 40 degrees. West Marine sells the same heater under their brand name. The heater works great as a heater but I find the anti-freeze setting generally always keeps the heater on, even when it’s not very cold inside. While I have considered buying a new heater, I recently became aware of external plugs that have built-in thermostats to turn on and off whatever is plugged into them. You simply plug the thermostat plug into the outlet, and then plug your heater (or whatever) into the plug and it then turns the heater on and off at roughly set temperatures. From what I’ve read these plugs are not particularly precise in terms of temp setting, but since otherwise my heater is always on, it seems like a reasonable fix to try as the thermostat plugs are not particularly expensive. Have any of you been using these, or tried these? Any feedback, recommendations, warning, etc.??
Rob
Rob
