bemiller75
- Mar 29, 2022
- C-302 C
- SHADOWFAX
With very cold weather one week away, I finally started to wrap up winterization of my 2016 Ranger R31S. I'm leaving it waterborne, and have set up an ice-eater. I also winterized fresh water using the air rig demonstrated on the As the Prop Turns video. I used pink antifreeze to winterize all four seawater systems (engine, generator, raw water washdown, and a/c). I had one problem -- I tried to use a funnel to limit the spilled antifreeze on the a/c system. Big mistake, the flow rate was too low, and the pump became air-bound. I normally use water pressure from the pier fresh water connection to fix air binding, but the pier fresh water is secured for the winter, and I don't see any vent fitting on the a/c pump.
My first question, can I use the air blowdown rig to blowdown the a/c seawater system? Seems like it would work. Are there better ideas, or reasons I shouldn't use air?
My second, more general question, because I am waterborne, I started adding pink after I shut the seacock, opened the strainer cap, started each of the four the systems, and saw level dropping in the strainer. Seems to me that I could be leaving raw water in the line between the seacock and the strainer. It may not be a big deal as long as my ice eater does its job, but what if the pier loses power? Should I be worried?
Thanks in advance for any advice.
