Dcsqatar
- Dec 11, 2018
- R-29 S
- Beautiful Red
I have a new R29S which will be going through its first winter in the Pacific Northwest. I researched numerous posts and then developed a detailed procedure as shown below. Maybe this might help others.
I am pretty comfortable with all decisions, although I am a little uncertain about (1) electrical plan - basically leave as is plugged into shore power, and (2) should I close all cabin hatches (my boat is in an uncovered slip) or leave a crack or two for ventilation. Any feedback would be welcome.
Winterizing 2020 Ranger 29S NW Edition (no AC, no generator)
Situation
• Wintering in Gig Harbor, WA
• Leave in water, in an uncovered slip at marina
• Owner away from end-Nov until end-Mar (4 months)
Engine (68 hours, 12 months old in July, plan on 1st service next summer) - general plan is to flush, leave cooling system protected with antifreeze, and install compartment heater
1. Close cooling water thru hull valve (seacock). With engine running, flush system with fresh water to seawater strainer. I used a 5 gallon bucket and a hose connected to a funnel which fits tightly into the strainer. Complete flush with freshwater with Salt Away. Leave water with Salt Away overnight. Next day, displace freshwater with antifreeze. My D4-300 takes about 4 gallons to fill seawater cooling system.
2. Install engine compartment heater to keep engine and most raw water pumps, strainers and plumbing above freezing. I chose Twin Hornet 45 (700w) heater based on good experience with friends’ boats, and exceptional safety and reliability features.
3. If cockpit is covered, open engine hatch slightly to promote ventilation
Fuel System
1. Fill tank with diesel to minimize water condensation. Leave a little room (I left 10 gallons) for fuel expansion.
2. Add diesel biocide/stabilizer. Volvo recommends Stanadyne, but I did not add anything extra as I purchased Valvtect Marine Diesel which comes complete with additives.
Electrical - general plan is to do nothing, and expect marina and/or neighbors to contact in the event of an extended power outage
1. Leave plugged in to marina shore power.
2. Leave battery switches in normal running positions (e.g., House, Engine, and Thruster “on’ and Parallel “off’)
3. Leave inverter/charger on and solar system configured as normal.
4. Open all unused 110v breakers.
Fresh Water System - after considering other options (e.g., blowing with 20 psi at pump, filling with non-toxic RV antifreeze, adding bleach to disinfect), decided draining as practical and leaving system open is most appropriate plan given low freezing risk and desire to minimize potential for freshwater system contamination.
1. Drain water from fresh water system, as practical, by opening all faucets and running pump, until no flow.
2. Turn off freshwater pump at switch.
3. Drain hot water heater as practical and reconnect hoses.
4. Remove hoses from discharge and suction of pump and drain any water. Leave hoses disconnected to increase system openness.
5. Remove hatch above water pump in cabin to share warmer cabin temps with bilge below
cabin.
Raw/Black Water System
1. Empty holding tank, flushing at least once with fresh water.
2. Close multi-use raw water thru hull valve (Stb side).
3. Open strainer and turn on first wash down pump and then flush head a few times while running freshwater into strainer. Repeat with antifreeze into strainer until antifreeze visible from washdown point and head.
4. Open washdown valve.
5. Flush a few oz of antifreeze placed directly into toilet.
6. Pour antifreeze into shower drain until antifreeze visible in discharged water.
7. Open door to head to share heat from main cabin.
Cabin - mitigate humidity issues but avoid high wattage heater
1. Provide dehumidifiers. I chose two low wattage “dew point control” heaters (Caframo 9406, 70w), backed up by desiccant driers. Expect the two dew point control heaters to provide sufficient heat to mitigate freezing issues in a closed cabin.
2. Close all hatches and head porthole.
Dinghy Outboard Engine (2.5 hp Suzuki 4 stroke) - as per owner’s manual
1. Fill internal tank 90% and add stabilizer to gas in tank.
2. Run engine for 5 minutes while flushing with freshwater, to distribute stabilized fuel
3. Close fuel tank vent and fuel shutoff switch/valve
4. Remove cover and spray power head with rust preventative (not a penetrative oil product).
5. Store upright preferably in a climate controlled location (off the boat)
Misc
1. Ensure trim tabs fully up
2. Confirm both bilge pumps functioning by adding water to bilge
3. Inspect cockpit drains and ensure clear
4. Empty refrigerators and clean but leave turned on, on low setting.
5. Dock boat stern to the south and/or east to maximize solar heating
6. Post contact numbers in cabin dockside window.
7. Leave keys with Marina office and a resident friend.
8. Ask friend to visit occasionally, inspect and run Wabasto heater briefly.
Situation
Fuel System
cabin.
Misc
