CaspersCruiser
- May 11, 2016
- R-27 Classic
- FMLT2709G112
- Cookie
I took my 2012 R27 out of the water today. A couple days ago, I drained the house water tank via the galley and head faucets. I also drained the hot water tank. After those items were done, I took the strainer off the house water pump and took it home to clean the screen (the marina water system was already turned off).
Today, I reinstalled the strainer and poured four gallons of pink into the water tank, but could not get the house water pump to prime and send pink to the faucets. I put an additional gallon of pink into the water tank, but still no joy.
Earlier this year, on the recommendation of Richard in Ranger Tugs parts, I replaced the original house water pump with a Johnson Flow Master 5.0 Variable Speed pump in an attempt to alleviate surging in the house water system. The improvement was marginal. Here's the pump:
https://www.hodgesmarine.com/Johnson-Pu ... 29-103.htm
Anyway, does anybody else have one of these pumps? Do you have any advice on getting it to prime? It's possible that this is related to the removal and reinstallation of the strainer. I did remove it and reinstall to no avail. Do I need to put more pink into the tank? Any other ideas?
